Another Lipo, charger, setup questions
Jarvis
Another Lipo, charger, setup questions - 07.24.2009, 02:07 PM
I have my buggy conversion complete and no batteries. I have the Tekno D8 buggy with the MMM 2200kv combo. I am running the clutch setup.
Guys, I am having a very hard time picking which Lipos to get! I don't mind spending the money to get good lithium batteries and it seems thunder power 5000 40C is the best of the best for racing. Is this true?
I want to make at least 20 minutes of hard racing as my goal. I understand a light trigger finger is always best and I plan to use that in longer races. We have a big race coming up in October and if the number of electric buggies doesn’t pick up we have to run with the Nitro guys. Sportsman A main is 30 minutes long and B main is 20. The electric main is going to be 12-15 depending on what the racers decide on.
My starting setup for the Hot Bodies D8 is as follows:
Differential Ratio: 4.3
Transmission Ratio: 1
Other Ratio: 1
Spur Tooth Count: 48
Pinion Tooth Count: 16
Total Voltage: 14.8
Motor KV: 2200
Tire Diameter (inches): 4.5
Tire Ballooning (inches): 0
Motor Current Draw: 0
Motor coil Ω: 0.006
Spur/Pinion Ratio: 3 : 1
Total Ratio: 12.9 : 1
Tire Circumference (inches): 14.14 inches (359.08 mm)
Total Motor Speed: 32560 RPM
Vehicle Speed: 33.79 mph (54.28 km/h)
Effective KV Value: 2200
KT constant: 0.61 oz-in/A
Motor Torque: Amperage not specified...
Final Torque: Amperage not specified...
Final Power: Amperage not specified...
I have an 18 tooth clutch bell on the way to put me at 38mph for bigger tracks
The car will not see over 40 mph. I feel that is fast enough for racing.
There is no battery size limit for my club racing and I run with all nitro buggies (10 minute main)!
For the guys that race is my starting setup okay or would you recommend I go to a 5S setup? If so, which battery?
If I stay with 4S I want to run two 2S in series, I have a touring car and a stadium truck, what batteries do you all recommend from personal experience?
Is there another battery equal to the performance of the Thunder Power 40C?
Is 40C overkill for what I want to do?
Is 30C a safe minimum for 1/8 conversions?
Do I need to buy another charger? If so, which one? Why?(I have a hyperion AC/DC EOS606i 50W)
Do I need a power supply? If so, which one? Why?
I know this is a lot of questions, but I want to make sure I am doing this right the first time and learn from other people’s mistakes. I am trying to keep the monster happy.
Thanks in advance!
Jarvis
