simplechamp
simplechamp's Avatar
08.05.2009, 09:06 PM
I also thought about getting some plastidip (in a can, not the spray) and pouring it in there, but I don't think it will ever harden. I need something that needs to be mixed so it cures via chemical reaction rather than air-dry seeing as it will be contained inside the tire and airflow is minimal if any.
I thought maybe if you wanted to use a compound that required air drying you could use a small aquarium air pump and tubing. The pump would blow air through the tubing into one of the wheel vents and it would escape from the other vent. Constant flow of air to cure the plasty-dip.
However figuring out how to make this work while the tire is rotating? That's another story...
