08.06.2009, 12:52 PM
With the 1521 1y 6s powered muggy I use a mixture of 50 and 100k in the CD. Ending up with something like 75-80k. That works alot better than the 50k did, and still allows for tight turning (on higher traction surfaces). I run 30k in the diffs, but I also run heavier tires and wheels, so I need thicker fluid to keep from diff-ing out. I mainly run on the road and thru grass so thicker fluid benefits my environment.
Comparing the muggy with the lst (about as close as you will get as they share almost everything save for the chassis) the Muggy does feel much more planted, turns alot better, and jumps almost as well. Either will show up a maxx/revo during bashing, just no comparison. The lst is more "fun" as it is a bit taller and will flip easier, so it keeps me on my toes. Tire selection makes the biggest difference.
