Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
RC-Monster Mike
Site Owner
RC-Monster Mike's Avatar
08.09.2009, 09:48 AM
It is generally considered bad practice to use set screws at 180 degrees from each other on a shaft in applications like this. This would be less secure than a single set screw. The very tip of both set screws becomes the only contact points on the shaft, while a single set screw allows the entire opposite side of the bore to engage the shaft - much larger surface area for securing the gear.
If 2 set screws are desired, they should be located 90 degrees apart. :)
