Thread Tools Rating: Thread Rating: 16 votes, 4.25 average. Display Modes
Ryu James
Ryu James's Avatar
08.25.2009, 12:28 PM
kaz,
have you tried mounting the motor up with that mount yet? i was looking at it a bit closer and am now wondering how you are going to make it work. because the mount sits the motor so high off the chassis you will have to move the motor in real close to be able to get your gear mesh. but you wont be able to do this it seems cuz the mount is so wide also and it will hit into the driveline or center diff mounts. my mount is only 2.5mm wider than the motor itself and it sits very close to the driveline. i am sure there is a way to make that mount work so i am just wondering if you have run into these issues and what you are planning to do to make it work. i guess you could notch the side of the mount just large enough for the driveline to go through it without touching it. anyway, am i seeing things right or does it just appear larger than it is?
Jammin SCRT10 Neu 1512 1y
