teknorc
08.27.2009, 12:24 PM
Originally Posted by MetalMan View Post
What if you set the mechanical brakes to lock at a higher brake input, so if you needed reverse you could just push the trigger slightly forward? You wouldn't get a lot of speed in reverse, but it could be enough to turn you around.
That will work but you have to drive without a lot of brakes. Here's why, with reverse and mechanical brakes, the ESC could go in to reverse (double brake pump) without the car actually being stopped. So if you don't double pump your brakes often (it's not all that common) then setting the mechanical brakes a little loose should give you some reverse throttle. Try it out and see if it works.
Tekno RC - Performance Parts
