SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
11.01.2009, 02:31 PM
Currently:
X-Ray T2R
Novak 17.5
35/78 gearing
2s Lipo
Will Try:
4s Hyperion G3 35C 1100mah Lipo geared much lower of course.
Will also try:
Tekin 1900 KV motor in my Losi 8ight
A note on cheat mode. I've only noticed a slight gain in top speed and a barely noticeable loss in torque when using cheat mode verses smart sense and 20 degrees of sensorless advance. However, motor temps run about 20 degrees warmer using cheat mode and 20 degrees of dynamic timing advance. I like how you can set cheat mode to activate at within an rpm range. However, I believe Novak motors are preset to 30 degrees of sensor advance, which means i can only set 15-20 degrees of dynamic advance in the MMPro to get 30 to 45 or 50 degrees of total timing advance.
Area 52 Ranch Raceway
T.R.C.R.
