2200kv Torq motor, how do I remove the rear bearing?
Freezebyte
2200kv Torq motor, how do I remove the rear bearing? - 11.09.2009, 05:27 PM
Ok, my Flux is under going an overhaul to check everything and I found the front bearing on my motor to be a little gritty so im gonna go ahead and replace it. I for the life of me however cannot figure out how to get to the rear bearing on the motor. I removed the 3 tiny little screws on the back plate, but I cannot see a way to safely remove the rear motor cap without using excessive force.
Am I missing something? And where can I go to purchase some high quality bearings for the Torq motor?
Also, im gonna go head and plug up those air holes in the front bell cap with some set screws to keep the dirt out. Any problem with this?
I also recently found that my fan is starting to make growling noises. I blew it out with the air compressor so I don't have to spend $12 on a new one but I"m wondering if I could even run this MMM system without the fan?
I was also surprised to see how many little rocks and dirt got on the PCB board, is it gonna be able to last with that much dirt/grit? I also found the fan cable to be nearly cut from the edge of the pcb board so I put some electrical tape on it to hopefully save it.
