sikeston34m
sikeston34m's Avatar
11.14.2009, 10:48 PM
Originally Posted by kneedeeppow View Post
i have been running my mmm straight outta the box in my mbx5t.as fun as it is it is a real handfull on the track.i want to make use of the castle link contraption and tune it so its a little less agressive on take off.i have played with the exp on my spectrum transmitter which has helped but still i get to about 1/3 throttle and it goes nuts.any tips out there for setting up the esc via the castlelink to calm it down a bit.i still want the speed i have just not till a little later in the trigger throw
Go into Castlelink and work with the throttle curve.
You can set full throttle to a percentage of full throttle. Just make the curve on the right side only go to 60% or so. You may have to play with this until you see the desired results.
Also, on punch control, set it to 100%. This will help tame take off somewhat.
I hope this helps
