MetalMan
MetalMan's Avatar
01.30.2006, 11:57 AM
48amps constant should be enough.
When too many amps are pulled from a Lipo, then its voltage will drop below 3volts/cell. This is where a LVC would be used, to stop the cells from dropping below 3volts. For some Lipos, at their maximum continuous amp draw, they will overheat when discharged continuously at that rate (like TP Lipos).
Maxamps isn't a bad company, and they have some of the best customer service. Those particular 4000mah cells perform rather well, too.
