01.30.2006, 11:59 AM
Originally Posted by bigabike
Wow, great post. Thanks for taking the time. I am learning a lot!
50v 470uf
The controller is only a couple of weeks old. It couldn't have more than 45 minutes run time on it and It cogged or shut down every time.
I wonder if it was bad to start, or If something else caused it. Anyway, I wouldn't want to replace the caps until I knew why it happened. I hope I can exchange it. I would hate to wait months sending it back to Germany.:020:
Thanks again for the great post!!!
NP.
The caps in the first picture you posted looked like they had rounded tops (especially the upper cap), but now the latest picture above seems to show they are flat (like they are supposed to be). Do you see how the tops are sort of "preforated"? This is so if the gas expands, these areas will split and release the gas without exploding. Do these look like they have been split? I really can't tell now from the pics.
If they are rounded/split, it can't be from excessive voltage as they are rated for 50v. Age is apparently not an issue either. The controller was never attached to the batteries in reverse polarity I suppose? I would think that if that were the case, you'd have a LOT more issues than just a couple of bad caps. I dunno...
Maybe the whole issue is as simple as dabid pointed out, but I don't like the fact that you saw "steam" from the caps at one point...
I hope the solution is simple for your sake.
