billy gunn
01.14.2010, 09:56 PM
Originally Posted by Gee View Post
I just got one last friday. It was a brand new kit a fellow put together but never had it started. But this retarded monkey is having problems starting it. Had it going for a few minutes then spent the next several afternoons trying again. Finally got it started yesterday and took it out for break in today. Was running alright. I was easy on the throttle then some mud puddles later the idle started dropping and I made some adjustment but to much one way and killed it when I hit the brakes. Spend the next hour in the brush trying to get the pig started again. Finally took off my belt and strapped it to the front and pulled it home. Frustrated as hell, I started up the savage x ss and made some noise to relieve the pressure. These things flood too easy and when they do it takes forever to get them started again. I really felt like mega hucking this sucker a few times already. A good thing I was wore out from cranking on it and by the time I caught my breath I had calmed down. I imagine it's just a learing curve but I've been startling weed eaters my whole life and haven't had one this freaking easy to flood. It's a brand new kit but I am thinking my first order may consist of another carb to try out. I haven't even had it full throttle yet.
Nice baja billy. What are some essential upgrades for a kit?
These things have problems with water?
Is a dom just the dominitor brand?
Slowkrawl. I like the flames. Looks cool. Why are you getting a kill switch? Is there something wrong with the one on yours?
They shouldn't flood too easily. If yours is stock it should come with a Walbro 668 carb. They are actually very easy carbs to work with, make sure your H is at 1.5 turns and your L is at 1.25. (I think those are the stock settings for a 668) Also small changes on the needles makes a big difference. Check and make sure you don't have an airleak, also check your spark plug. If its hard starting, I have found those to be two common problems.
Also if it floods just take out the spark plug, tip the baja back, hold full throttle, and pull it a few times. Replace the plug and you should be able to start it.
Essential upgrade? I don't know I would recommend almost everything on mine. I think it really depends on where you drive, but outerwears prefilters, and the TR enclosed clutch setup if you drive in dirt and sand are good places to start.
A little water will be no problem, as usual the radio box is probably the most sensitive part. Obviously sucking water in the airfilter is bad, but an outerwears is water resistant.
The dominator line of pipes are built by DDM (Daves Discount Motors), they are all solid pipes.
The kill switch is just a third channel kill switch. It acts as a failsafe, and also so you can kill the engine using the third channel on your radio.
