Just some info.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Just some info. - 01.25.2010, 07:57 AM
Just an added trick that really helps with handling issues. After putting all of that work into putting your wheels and tires together you might want to balance your wheels for better performance. If your wheels are out of balance even just a little bit it can cause allot of vibration, which slows your top speed down quite abit, and also retards your accelleration. Once you test the difference between a set of balanced wheels and an unbalanced wheels the results are amazing. It really does help even if your just bashing. Unbalanced wheels take more effort from your drivetrain and powerplant, which shortens your run times and affects your overall handling. Not to mention shortens the life of your bearings. Just my 2cents. Good luck with that.
SUPERMAXX YOUR LIFE.
