FS: mamba monster v3 airtronics servo Mod1 pinions lipos
hootie7159
"1.21 GIGAWATTS!!!"
hootie7159's Avatar
FS: mamba monster v3 airtronics servo Mod1 pinions lipos - 03.07.2010, 12:35 AM
Couple things for sale:
Mamba Monster V3....nothing wrong with it...works great!...but has a few mods (waterproofed with red liquid tape...rerouted fan wire so that it can now be powered through an extra channel in your rx....the on/off switch has been removed...the case has been cut in order to remove the MMM from its case without having to de-solder the connectors....the bottom of the case is loose but is held together with velcro tape) all of the mods are purely cosmetic, the ESC works just fine...will come with castle link...not pictured...
Airtonics 94359 servo...all of the seams in the case were covered in red liquid tape as well to water proof it...in great workign order...
Mod1 pinions...all are used but none of the teeth are jagged and all are in good shape....included are: (21t, 19t, 18tx2, 17tx2, 16t, 15tx2, 14t, 13t, 12t, 11tx2)...over $140 worth of pinions.
Rc car stand...barely used..only dirty...
Tactic 2.4ghz rx....used once...in great working order...
Lipos:
2s 5000mah 20C zippy-H...slightly puffed....highly recommend only using this in a 2wd slash-type of vehicle setup....any 1/8th scale setup will puff it back up...however, its still takes in 4.15v/cell and holds it charge ....
2s 5000mah 25C (i believe) flightmax zippy lipo...nothing wrong with it works great...always balanced and charged....
3s 5000mah 25C(i believe as well...the 2s and 3s zippy flightmaxes used to be a 5s pack) nothing wrong with it as well..
3s 5000mah 25C(not sure...either 25C or 30C) turnigy lipo....this pack is slightly puffed as well and i highhighly recommend using it in a 2wd setup as well...nothing 1/8th scale...still holds a charge and is balanced....
4s 4350mah 20C(not sure...either 20C or 25C) hyperion lipo...in great shape..solid...always balanced and charged....
i have 100% feedback on ebay as cacuucd...and over at rc-tech.com as hootie7159...BTW linc did all the lipos for me...top notch work!.....best way to get a hold of me is either email: hootie71@hotmail.com or text me at 9253482936.....NOT ACCEPTING ANY TRADES...thanks for looking and let me know if you need any more pictures of anything....
Losi SCTE
MMP/1410 3800kv
2s 65C 5600mah proteks
Dx3s
