Are JST-EH and JST-XH balance taps compatible?
simplechamp
simplechamp's Avatar
Are JST-EH and JST-XH balance taps compatible? - 05.08.2010, 04:21 PM
So I bought a pair of Neu lipos, and noticed they use JST-EH balance taps. Since all my current packs use JST-XH I figured I would buy a balance board to adapt the EH type taps to my iCharger XH inputs. But then I looked on A-main and they say the balance board I need will work with both JST-XH and JST-EH type taps. So do I even need to buy this balance board? Are the plugs slightly different but close enough to fit the same input, because it looks like the wiring is the same. I might get it anyway because it's more convenient than plugging directly into the charger and using different adapters for multiple packs. I just want to make sure this will work with both EH and XH taps.
If you zoom in on the pictures you can see the balance board says XH and EH right on it. The reason a bit confused is because the second two links show separate balance boards for the XH and EH types.
Supposedly good for both types:
http://www.amainhobbies.com/product_...-KoKamNeuOrion
Supposedly need diffferent:
http://www.amainhobbies.com/product_...okam-Neu-Orion
http://www.amainhobbies.com/product_...-Align-E-Flite
