_dV
05.11.2010, 08:59 AM
The battery tray from the Vorza looked like a good way to keep the battery secure in the TVPs. Took me some time to track one down but unfortunately once i got it i found it was unsuitable. The expanded areas on one end for the battery wires meant it wouldn't quite fit between the TVPs. The way it mounts also raised the battery up more than i had hoped (see second pic). The holder mounting holes are also not properly asymmetric in that if you wanted to rotate the holder 180 degrees to have the battery wires at the other end you couldn't use the same holes in the mounting surface.
Eventually i found these Tekno battery trays. They are simple, light and should do the job. They take batteries up to 51mm wide and the longer one can handle batteries up to 165mm long. The long one fits in the new XL layout nps
