Thread Tools Rating: Thread Rating: 12 votes, 5.00 average. Display Modes
JThiessen
JThiessen's Avatar
05.18.2010, 03:32 PM
Originally Posted by jpoprock View Post
WOW WOW WOW! Thank you so much Ray!!! That is awesome!!!! Now I "get it"! I wonder why you chose to cut the piece with the template facing down? Wouldn't it be a little easier if you could see exactly where you were supposed to go? I realize that you're feeling your way thru it, but i would prefer the stock piece facing up so I could see the path.
Also... is it important to wear gloves? Or is that preference? I have a shop vac, but I wonder if you need to buy one of those special dry wall filters for it when sucking up carbon fiber?
I just can't believe how easy this is, now that I've seen it. I'm gonna buy a router table at Harbor Freight now pronto! The next thing I need to work on is the shank. So basically you want to use the smaller 1/8" bits and the shank for small areas, and the 1/4" bit for larger sections. Is that right? I believe that i already have a shank and 1/8" bit for my dremel, but I don't have a 1/4" bit I don't think. I may, since I own a Rotozip tool.
Boy... you've just opened a pandora's box for me!! My wife is going to HATE ME now. HA!!!
Jason
The reason he was doing it upside down was so that the non-cutting portion of the bit was acting as the guide. If you wanted to do it the other way around, you would need a bit with a guide bearing on the end of it - which only come in 1/4" diameter or larger. If you dont have any radii smaller than 1/8'' (half the 1/4" dia) then your fine.
Regarding gloves and power equipment. General rule of thumb is to NEVER wear anything that can get caught in a moving part and pull your body parts into the blade. However, with CF, you have that nasty dust and slivers to contend with. Plus the gloves he had on were more likely to tear than pull - but as close as his finger got a few times, I bet he would have ended up with a nasty little chunk taken out of the finger. Personally, I would do it without gloves, or maybe even try some of those rubber sewing thimbles.
ps. Check your local Craigslist before you go buy a new one. A variable speed router would also be very beneficial for projects like this.
