thzero
07.04.2010, 11:08 AM
The other thing is that currently the software is built using .NET. You'd need to install Mono on either the Android or iPhone; better luck with the Android since you can mod it. As long as Mono supports enough of the APIs it might work, but I doubt it has the support for interfacing with USB; don't know for sure as haven't looked into it. And then there is USB hosting issue.
Originally Posted by Finnster View Post
^^^ I figured it was dueo to some limitation of the USB ports they have. OTOH, I know you can use the droid phones (and more) as a tether to a laptop to the phones data connection.
Surely if you can run internet thru the usb port to a laptop, there has got to be some way to interface to a controller.
