07.07.2010, 03:48 PM
Extending runtime boils down to this: perform less "work". This is done by reducing weight, reducing gearing, smooth drive style, etc; basically making sure the current draw is as low as possible.
Refrain from high bursts of speed (fairly constant throttle) to avoid high current bursts. ESC settings can help somewhat, but may make your vehicle feel less "responsive". Higher voltage with lower kv motor can increase efficiency (less I^2*R losses), which translates to more battery power getting to the ground.
