Scott711
Scott711's Avatar
02.22.2006, 12:31 AM
LOL.....The yes applies to the off topic part. They have a similar pressed end plate, I'm not sure about suffering the same design. If you mean motor leads epoxied to the can prior to exiting the hole, then yes. The end cap just pushes back on. It is for this reason it is a good idea to get one of mikes heat sink/motor clamps. It helps keep the end cap on. A light file job on the sharp edges should help keep the insulation from getting cut. If you really wanted to you could enlarge the hole and make room for insulator but I think it's more than you need. Mike has also advised to try and secure the leads between the esc and the motor to prevent movement of the wires. Sorry for the assumptions.
