FS: Revo, TX/RXs, MGM 22418, MGM USB Link, Castle Link, Mamba 25, MM, 10XL
bensf
FS: Revo, TX/RXs, MGM 22418, MGM USB Link, Castle Link, Mamba 25, MM, 10XL - 07.24.2010, 01:23 AM
Sorry I forgot about not posting prices.
Revo Roller, One of the diffs is shot. RPM Arms and front knuckles. Missing rear body post. 3racing chassis modifided to take E-Maxx tranny with custom single motor mount. Aluminum wheel hexes. Kippster slipper, its basically a Strobe slipper that uses RRP spurs instead of Ofna spurs.
MGM 22418 The on/off switch came off of one of them. Connectors included.
MGM USB kit. Allows you to connect the 22418 to the computer to read info about the last run (min voltage max rpm max amps and stuff like that) and adjust all of the settings.
Futuba 3PM w/ FAAST Transmitter and Reciever
Feigao 10XL, Black model
TrueRC 5s2p 8000mAh pack. A little beat up but works fine.
Mamba Max I haven't used it much, PO's description (jnev), "The separate MM ESC (which I actually received today), has a the switch wire torn off (must have happened during shipping) and has a Novak cap soldered on the the wires that lead to the battery as well. The case also has some holes drilled into it for additional cooling. So other than the switch wires, (which isn't hard to fix, just need to solder them on) it is in perfect condition. The previous owner (entjoles before jnev) also said that it can run 5s no problem ." Connectors and box included included, can't find the instructions though.
Castle link
Last edited by BrianG; 07.24.2010 at 01:43 AM. Reason: Added image from other thread...
