billybob
07.27.2010, 08:57 PM
I set him up with an aveox (1509 sized) of 2768kv set up to run great on 3s. But the vxl esc will not run the 4 pole motor.. He has every component aside from an esc. I'm gonna try the basic bandaids to get the esc to last until he can buy a better unit.
Going to install some low ESR 3900uF capacitors to help kill some of the current ripple, and install an external BEC and not use the crappy linear regulator in the vxl. Scrubbing 12.6v to 6.0 creates a lot of heat. I think it will make 15 minutes
We did the External BEC today...Over heated in the grass...We are going to the track tomorrow for a t and t...
If it over heats we are going to try Capacitors. Hopefully that works! If it isnt already fixed... Having Ben at my side has helped greatly! And He def knows his s$!t !!!!!!
