Mamba Max Pro ESC, Sensored.
MindThoughts
Mamba Max Pro ESC, Sensored. - 08.16.2010, 07:22 PM
Originally Posted by whitrzac View Post
I still don't have a battery, but the chassis and motor should be here this week.
I decided to go with a tekin 1400kv over a 15/1409 because the track is a tight indoor track, and I will need the smoothness of the sensors...
Sounds great. Thank you for the update. Will you be using the Mamba Max Pro sensored ESC? have you considered using all aluminum screws to help bring the weight down? I'm going to go with all aluminum screws and if any break, I'll replace those with a stronger material screw.
