Byte
08.19.2010, 03:23 PM
It takes quite a long time to get to the programming mode, longer than the 10 secs. that the manual says, IIRC. Make sure your endpoint/brake is at 100 or 125 percent. Will it calibrate to the radio? I think you will need to do this before you can get into programming mode.
I'm not sure if it's calibrated to the TX, is there any way of seeing this? I just did what the manual said:
If
transmitter or receiver is changed for a different one, it is recommended to do the programming again – it is enough to start the programming mode so that new
parameters of control signal are saved (switch on with full throttle forward, wait 3 beeps, move to full throttle backward, 1 beep, move to neutral, 2 beeps, controller
switch off
I will set the endpoints at 125% and try it again. Thank you for your help!
@Texas: those USB thingy's are pricey imo, I'll try to program it through the TX.
