pinkpanda3310
pinkpanda3310's Avatar
10.10.2010, 08:40 AM
Originally Posted by KniteWulfe View Post
It's the same for both of my turnigy 4500 30c packs and the pairs 5200 30c packs. In fact it is worse with the 5200s.
I notice on those graphs that the issue arises when the temp gets to 125-130. Your larger mah packs probably help to heat the motor just that little bit quicker.
I would imagine the esc would be getting fluctuations of temp at the same point but harder to notice if you are just using a gun and that's roughly when the fan kicks in.
Given it happens to any motor but the issue arises when the motor gets to a certain temp, one might assume mount is not integral at those temps. However, the car still rolls freely with no binding. Does it roll freely in reverse? I ask because that would be the direction of pressure on the drivetrain under acceleration.
