Go Back   RC-Monster Forums > Support Forums > Unlimited Engineering
Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
10.12.2010, 04:12 AM
First off, Supershocks are a different size than any stock Ofna shock...Second, they have TiNi shock shafts which no stock Ofna shock has...Third, Robin was in contact with Ofna about everything that he used Ofna parts on or based off of an Ofna Design. In fact, Robin took the Ofna 3-shoe clutch, redesigned it into a 4-shoe clutch, then gave the rights to Ofna, and now they produce and sell the 4-shoe clutch that Robin designed.
Also, the 6-Spider and 8-Spider diffs are not "simply" Ofna diffs...they have been modified for use in UE designs, and are not the same as a stock Ofna diff you buy anywhere else. Sure, they are based on Ofna diffs, and use Ofna parts, but they also use UE parts, and again, Robin had permission from Ofna to do all of this.
Robin saw no need to redesign the wheel, when he could, he used existing parts and or modified existing parts to work how he wanted or needed them to, with permission.
-Chad
PM ME IF YOU HAVE THE BELOW:
