BIG-block
11.13.2010, 10:46 AM
Hey man, that is a nice looking buggy. How did you go fitting the 1515 motor in it? Was there enough room? I am asking because I have one of these and the 36mm motor is almost all the way against the vertical chassis. Doesn't look like there is enough room for the 1515 so just wondering if you had to grind any material away. Also what gearing are you running? (spur and pinion)
In Australia the same buggy is marketed as GV (Great Vigor) Cage but in the states it is the XTM Rail. They pretty much come with all the same gear but it does look like that there are some differences around the front and rear bulkheads and diffs look slightly different. In regards to the electronics the Cage comes with a shitty AM radio (went in the bin as I opened the box) but the Rail has the Airtronics 2.4.
