DrKnow65
DrKnow65's Avatar
02.03.2011, 10:44 AM
Thanks _P_, I forgot to mention that I'm going to have to recess the two screws that hold the mount together just under the motor. It will be easy though, I'll just use a countersink bit I have ($8 90 degree carbide router bit) and switch to a flat head screw so it will sit flush and not impede the larger can 1717. Then I can run a small pinion if I want.
