Using an AIR Controller for Car use... help and advice please.
Jahay
Using an AIR Controller for Car use... help and advice please. - 02.09.2011, 08:27 AM
Hi Guys... Right... I want to upgrade to an Air style control, as i know i wil have better control with it over a pistol controller...
My TX of choice.. Has to be the hobbyKing controller pictured below... as so many have had great results with the pistol style HK controller (has a longer range than Spektrum!), i thought i would give this a go.
http://www.hobbycity.com/hobbyking/s...idProduct=8338
Also please bear in mind, this will be going in my savage... and i will be using a Castle ICE HV 160 Amp air ESC which was originally designed to work with air controllers. So this should mean that i do not require a PISTEX chip??? Correct???
Now as these are air controllers... they do not have the usual return springs in them like Car TXs... I know people have been able to install these... but i have never seen any write ups... can anyone enlighten me?
As this has 4 channels.. i will be installing 2 fans on the ESC for cooling and one on the motor...I would like to be able to turn these on and off from the controller... is that possible do you thinik??
Can someone help me out here?
THANKS
