02.18.2011, 08:40 PM
Hmm, I could not find a pic of the inside of a traxxas splined wheel. Anyone have one?
I know the traxxas 17mm hubs will fit any 17mm rim, I also have the ofna blue hex adapters and plenty of the maxximizer hex hubs and savage large wheel nuts. So I have a few options.
I will start with 17mm wheels and go from there.
And the castle 3434 770kv motor fits nicely on the erevo/summit motor mount. I had to use the low cg holes as a 25t mod 1 pinion would not fit in otherwise. The castle motors have 1 pair of 25mm spaced m3 threaded holes and 1 pair of 30mm m3 threaded holes. I use the 25mm spacing and the lcg holes in the mount to fit the 25t mod 1 pinion.
I am using a 40t mod1 nitro revo spur gear, nothing larger will fit with the 15t pinion and the stock adjustment slot. I can go down to a 34t pinion if I want more speed, but I think 30mph in 2nd gear will be plenty for this beast.
Now for a question: do you think I can run the revo setback rear arms with a set of cvds? I would like the extra wheelbase, but can sacrifice if there will be issues. I understand it puts the rear driveshafts at an angle, will this be an issue? For some reason I vaguely remember someone having problems with cvds and not sliders with the setbacks...
