Semi Pro
Semi Pro's Avatar
05.21.2011, 10:26 PM
ok since no one has jumped in i will try and help, i dont know what your planed layout for packs is yet but based on afew other serpents i have seen built your going to want atleast a 35c 4000mah worth of packs for the 2250kv and closer to 5000mah 35c for the 2650, geared for 80mph its going to be an amp hog and run times arent going to be all that great
if you want it to be reliable i would gear it for 65 and then gear up depending on motor and pack heat
i dont think you have alot of options for the packs to be anywhere other than the sides
