dtnel
09.03.2011, 12:19 AM
Originally Posted by cmac View Post
Do you guys have any idea what size shims I should use to stop the little bit of side to side movement of the diffs?
I've been digging through this thread a little bit tonight and came across this post you had about the side to side movement. Did it take several shims to get the output shafts set right or not ? I'm worried about me putting the shims inbetween the output shaft cross pin and the o-ring. The shims aren't going to cause a problem with this are they? I don't want to have To redo all this again.
