cmac
cmac's Avatar
09.03.2011, 03:25 AM
Originally Posted by dtnel View Post
I've been digging through this thread a little bit tonight and came across this post you had about the side to side movement. Did it take several shims to get the output shafts set right or not ? I'm worried about me putting the shims inbetween the output shaft cross pin and the o-ring. The shims aren't going to cause a problem with this are they? I don't want to have To redo all this again.
I believe I had to put two shims just on one side. It was between the output shaft and the bearing (outside the diff case but inside the hybrid bulkhead ). I can't remember if it was on the ring gear side or the other side. I think I tried it both ways and one side was better than the other. Just don't locktite everything down until you find the right combo. Take your time and you won't have to ever do it again, and no it did not cause any problems at all in fact it helped smooth everything out.
