Anything is possible
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Anything is possible - 12.11.2011, 11:17 AM
Originally Posted by cmac View Post
I don't know why I didn't think of this but my tires are directional. I can't swap them for the other side.
Well anything is possible, but honestly unless one tire is totally different from the rest I doubt that it would make much of a change for your particular problem. And even though the tread is directional you can still try swapping them around for a test. Even so as long as they are all the same size, and the weights do not differ more than an ounce or two I would find it hard to believe that it would change your driving experience to swap them around. The only way tires would affect steering would be if they were different sizes like they do with some oval track racing. They put small diameter tires on the left side to make the vehicle naturally want to turn left making it easier to steer through the turns.
What you have been describing as your torque steer issue would not be affected by the tires unless one side is balooning drastically. Alignment maybe, but this seems more like a diff issue where one side is receiving more power (rotation) than the other. You have to try whatever comes to mind after you do a little knowledge based elimination. Eliminate what you know for sure is not your problem, and make a list of what you do suspect, and then test that theory one by one until you have tried everything that you can think of, or the problem disapears.
Steering issues under power can only be caused by a few things. The servo is always the first place to look. Second would be the steering linkages to make sure that there is no slack or binding of any kind. If it operates smoothly by hand than it should do the same under servo power as long as you have the right servo for your setup. Next is the drivetrain itself. Closely examine each axle for any unusual binding due to a bad bearing or improper installation. The diffs are next in the line. Diff slipage is an individual descresion and you have to set yours up to match your expectations, but you still have to make sure that they are smooth as silk and have no binding what so ever. The last thing in the drive line is the transimission or center diff including whatever slipper you might be using. Make sure that everything is operating smoothly and easily as it should. I cannot think of anything else that will effect your vehicle in the way that you have described.
SUPERMAXX YOUR LIFE.
Currently Active Users Viewing This Thread: 3 (0 members and 3 guests)
