01.29.2012, 02:39 PM
Originally Posted by MAYHEM6969 View Post
So do they come with shims if not what size do you need and what brand of diff is that in case i need to repair one? And i was wondering what gear ratio will i need i have a stock emaxx with MM
They are ofna buggy diffs, not sure of the exact model but you can find them by doing a visual comparison to ones for sale one ebay:
http://www.ebay.co.uk/itm/New-Ofna-P...item336fd42bc7
Looks like the ones ( look at the pinion gear & how it is reduced to 5mm at the end, most others are 8mm all the way along ).
If shims are needed, then they will be 8x10x0.2mm shims, easy to find:
http://www.amainhobbies.com/product_...02mm-Washer-10
What do you mean by stock emaxx & MM- do you mean the newer 3908 & the MMM ( MambaMonster ( Max ) = MMM, MambaMax = MM; don't mix them up... ) system? In that case, you ony need to gear up 1-2 teeth on the pinion gear to get the same overall ratio as you would have with the stock diffs. I recommend something around 22-24/65 on 4s lipo for ~40mph, but let your motor, esc & battery temps guide you if you want to go faster ( a hot motor and cool esc means you need to gear up, viceversa means gear down ). More lovely info about gearing and emaxx related stuff in my sig
