Thread Tools Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Ascender
Ascender's Avatar
03.11.2012, 04:08 AM
Wow, haven't been here in a while.
So, questions:
1. One of your original complaints about the Flux was that it was a "fat pig", yet you've actually made it a lot heavier by sticking the stock plates inside the TCS TVPs. As far as I know, NOBODY has ever managed to bend or break a TCS plate yet. Plus, the reason you had problems with the stock plates in the first place was that you removed all of the cross-bracing that makes the Savage line so strong when you took out the radio box and motor plate. Having the stock sandwiched in there is just pointless weight.
Second, you've missed the best proven handling improvements for the Savage, which are simply lowering the truck by means of an internal spacer in the shock, and getting an XL-length chassis. TCS makes a good one, or you can do like I did and order a set of XL-length carbon fiber TVPs from Platinum RC. They weigh less than the stock 2.5mm plates, and they're as strong or stronger than the TCS pieces.
