othello
HV basher
08.17.2013, 06:03 PM
I will add an external BEC for sure. The 5A BEC seems a bit weak for my taste either. The 12V 80x80 fan is powered off one of the 4s batteries. Gear mesh is set relatively loose compared to my 1/8th cars ... smooth running with no binding. Start Power low was the default setting ... i thought this will be easier for the batteries so i kept this setting. I don't think that there is a neutral shift, as i'm using the same radio with different cars and never have experienced troubles when starting from 0 rpm either back or forward. Thanks for your inputs and ideas.
There is one member on our austrian forum who has reported that on his race track 9 out of 9 XL2 ESC are showing the same behaviour. When changing the ESC to an MGM or Atos the behaviour is gone. So must be the ESC. While racing the issue is sort of non existent since they won't brake their car to 0 rpm.
On the other hand we have one member with a Baja 5e who is not experiencing this phenomenon with his blur rtr setup and another one who is using 2 XL2, one in his losi five and one in his Crick Corr Truck and he is reporting having the same issues as i do.
I haven't searched other forums but this can't be a problem which happens only with my setup.
