jcflyer
09.06.2016, 08:50 PM
I doubt you're holding 3.7 volts under load unless its geared pretty conservative - gotta guess on tire ballooning as well(soft tires will grow more). For speed run applications, I set the voltage to whatever the LVC is set to. For day-to-day, I use 3.2 for calculations....I rarely verify the actual speed, though(unless its a speed run, I don't care what the actual number is - more of a feel thing for regular running).
It is geared pretty easy 17t/54t pinion and spur gears. The ESC has a log and it shows the voltage to be above 44.4 volts on a full charge, I have be down around the 70ish% range before it dips below 44.4 volts. The tires are BRP slicks the have absolutely zero ballooning in them!!! I am not doing speed runs this is drag racing 132'!!! I don't really care about the numbers that much I was just comparing the logs to the calculator, trying to figure which is accurate!!! That way I can tune it better...
