Mark Fradkin
Rad Frad
07.17.2006, 03:33 PM
Originally Posted by BrianG
When I programmed mine, I followed the manual to the letter and I didn't have any problems. I read the instructions until I understood the steps so I wouldn't have to try to read it again between each step and possibly lose my spot.
To beep, it has to be hooked to the motor (since that is the part that beeps). Like the manual says, disconnect the drive train (pinion will do) so if you make a mistake and actually aren't in programming, the truck won't take off on you.
The sky- tech... website has a video plus tips on selections available. I also read the instructions carefully understanding them before I started. I had no problems and ran it yesterday. I was happy w/ the performance
Emaxx apachee 5s 2packs parallel (LI poly normal setting)
