Gustav
Gustav's Avatar
07.19.2006, 10:08 PM
I got the rear diff assembled and the rear end back together and i don't see any problem at all,they're spot on.
I took the shafts down in the lathe to 3.5mm from the centre of the bevel gear pin hole,the same as the original outdrive.
All i had was 20k oil so i used that but only just over half full since it's a little thick.Now i just need my chassis to arrive and i'm ready to go.:027:
Off topic but I need a body to use on the non-extended g-maxx.Any suggestions? I want to cover the batts as much as possible,i know it won't cover them completely.
