08.07.2006, 08:11 PM
Originally Posted by Finnster
Lastly, I don't think the plastic is oil-impreged. Some nylon is, but this is approved for 3A sanitary/FDA usage (dairy and food contact.) It is very slippery tho, close to teflon. This is often used as machinery guardrails, slides and such.
Yeah, that's what it looked like - the stuff restaurants use as a food prep surface/cutting board. I was thinking of the Subway food prep area when I saw that.
Brian, you had bigger tires on yours w/ the 14t as well, correct?
Actually, my tires were the standard size, just heavy due to the tread design. The whole truck was heavier due to material choices, and I used 14T. My truck was a little over 14lbs with 14 GP3300 cells. I'd increase a tooth for every two pounds lighter than 14. So, if you are at 12lbs loaded, I'd try a 15T. When I went with 15T, my ESC heated up more, so it should be just about right if yours is lighter. If you had the cash, I'd say get a 15T and a 16T, but I think 15T will be just about right for that motor.
