IBJAMMIN
IBJAMMIN's Avatar
10.29.2006, 07:20 PM
I'm getting ready to convert my CRT to brushless and see there is a problem with pinion gears? I think your pinion problem is caused by chassis flex the nitro crt has a problem also the fix for the nitro motor is a 1 peice extended motor mount. Look into a brace to eliminate the flex in the center of the chassis by eliminating the battery box and brake servo and cutting down the top brace you have weakend the chassis. Grab the front and back of the truck and twist it and see if the pinion and spur mesh changes? :)
