C.H.U.D.
05.22.2005, 05:11 AM
Originally posted by luihed
I dont get it..... the 9L and 13s are smaller motors than the 7XL and I thought the 7XL is too hot for 20 cells:C: .... I have a 7XL right now, can I run 22.2v on it?
Im definately gonna run 22.2v lipo too but I still dont have a clue to what motor will give me the fasted speed..... I know its 2400 or 2000 for teh lehner or 8XL for the feigao, but for some reason 2000 or 2400 is not the same as 8XL..... Im too confused.....:C:
The problem w/ choosing a voltage, amperage, motor, speed control, yadda yadda yadda is that each of the aforementioned (and many more items like weight, resistance, ambient temp, final drive ratio, etc.) factor in to how your truck/car will perform.
The motor has several factors alone that you may consider when choosing the correct one. Such as its efficiency at a particular voltage/rpm, the amount of torque it puts out, max rpm's, total horsepower, etc.
I have some data for the 7XL at 14.4 and 22.2 volts. I'm still working on this calculator and it definately needs some input/output tuning, but maybe the following numbers will give you an idea of what these motors can do. For comparison purposes I put the Feigao 7XL @ 14.4v and 22.2v. Also listed is the Plettenberg MAXXimum @ 22.2v.
Remember that these are just numbers, your mileage may vary.
btw, I believe the Feigao's are rated at 50000 max rpm's. You'll see that 22.2v puts you just above that. Of course depending on many factors you'll probably not get to 50000 rpm's.
If something looks fishy about the numbers below lemme know. I haven't looked at my calculator in a while, but I know that it can use some improvements.
Feigao 7XL @ 14.4v
~~ [14.4 volts, 30 amps] ~~
voltageconstant: .0060
Kt: .0080 (oz-In/I)
rpm: 33900.6240
powerin: 432.0 watts
powerout: 362.9160 watts
HP: .4864
efficiency: 84.00%
torque: 13.44 oz-in
~~ [14.4 volts, 40 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 33767.2320
powerin: 576.0 watts
powerout: 503.2480 watts
HP: .6745
efficiency: 87.00%
torque: 19.20 oz-in
~~ [14.4 volts, 50 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 33633.8400
powerin: 720.0 watts
powerout: 642.4600 watts
HP: .8612
efficiency: 89.00%
torque: 24.96 oz-in
~~ [14.4 volts, 60 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 33500.4480
powerin: 864.0 watts
powerout: 780.5520 watts
HP: 1.0463
efficiency: 90.00%
torque: 30.72 oz-in
~~ [14.4 volts, 70 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 33367.0560
powerin: 1008.0 watts
powerout: 917.5240 watts
HP: 1.2299
efficiency: 91.00%
torque: 36.48 oz-in
~~ [14.4 volts, 80 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 33233.6640
powerin: 1152.0 watts
powerout: 1053.3760 watts
HP: 1.4120
efficiency: 91.00%
torque: 42.24 oz-in
~~ [14.4 volts, 90 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 33100.2720
powerin: 1296.0 watts
powerout: 1188.1080 watts
HP: 1.5926
efficiency: 91.00%
torque: 48.00 oz-in
~~ [14.4 volts, 100 amps] ~~
Kt: .0080 (oz-In/I)
rpm: 32966.8800
powerin: 1440.0 watts
powerout: 1321.7200 watts
HP: 1.7717
efficiency: 91.00%
torque: 53.76 oz-in
Feigao 7XL @ 22.2v
~~ [22.2 volts, 30 amps] ~~
voltageconstant: .0093
Kt: .0125 (oz-In/I)
rpm: 52480.2240
powerin: 666.0 watts
powerout: 561.8160 watts
HP: .7531
efficiency: 84.00%
torque: 13.44 oz-in
~~ [22.2 volts, 40 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 52346.8320
powerin: 888.0 watts
powerout: 780.1480 watts
HP: 1.0457
efficiency: 87.00%
torque: 19.20 oz-in
~~ [22.2 volts, 50 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 52213.4400
powerin: 1110.0 watts
powerout: 997.3600 watts
HP: 1.3369
efficiency: 89.00%
torque: 24.96 oz-in
~~ [22.2 volts, 60 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 52080.0480
powerin: 1332.0 watts
powerout: 1213.4520 watts
HP: 1.6266
efficiency: 91.00%
torque: 30.72 oz-in
~~ [22.2 volts, 70 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 51946.6560
powerin: 1554.0 watts
powerout: 1428.4240 watts
HP: 1.9147
efficiency: 91.00%
torque: 36.48 oz-in
~~ [22.2 volts, 80 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 51813.2640
powerin: 1776.0 watts
powerout: 1642.2760 watts
HP: 2.2014
efficiency: 92.00%
torque: 42.24 oz-in
~~ [22.2 volts, 90 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 51679.8720
powerin: 1998.0 watts
powerout: 1855.0080 watts
HP: 2.4866
efficiency: 92.00%
torque: 48.00 oz-in
~~ [22.2 volts, 100 amps] ~~
Kt: .0125 (oz-In/I)
rpm: 51546.4800
powerin: 2220.0 watts
powerout: 2066.6200 watts
HP: 2.7702
efficiency: 93.00%
torque: 53.76 oz-in
Plett HP 220/40/A2 @ 22.2v
voltageconstant: .0101
Kt: .0135 (oz-In/I)
rpm: 47567.2500
powerout: 625.5517 watts
HP: .8385
efficiency: 93.00%
torque: 17.28 oz-in
Kt: .0135 (oz-In/I)
rpm: 47239.2000
powerout: 837.2376 watts
HP: 1.1223
efficiency: 94.00%
torque: 23.04 oz-in
Kt: .0135 (oz-In/I)
rpm: 46911.1500
powerout: 1045.9234 watts
HP: 1.4020
efficiency: 94.00%
torque: 28.80 oz-in
Kt: .0135 (oz-In/I)
rpm: 46583.1000
powerout: 1251.6093 watts
HP: 1.6777
efficiency: 93.00%
torque: 34.56 oz-in
Kt: .0135 (oz-In/I)
rpm: 46255.0500
powerout: 1454.2951 watts
HP: 1.9494
efficiency: 93.00%
torque: 42.24 oz-in
Kt: .0135 (oz-In/I)
rpm: 45927.0000
powerout: 1653.9810 watts
HP: 2.2171
efficiency: 93.00%
torque: 48.00 oz-in
Kt: .0135 (oz-In/I)
rpm: 45598.9500
powerout: 1850.6668 watts
HP: 2.4807
efficiency: 92.00%
torque: 53.76 oz-in
Kt: .0135 (oz-In/I)
rpm: 45270.9000
powerout: 2044.3527 watts
HP: 2.7404
efficiency: 92.00%
torque: 59.52 oz-in
