crazyjr
crazyjr's Avatar
11.20.2006, 10:18 PM
Originally Posted by neweuser
I think his question is the MM esc, if so, yes, it'll do fine with a 9xl on 14 cells. I believe crazyjr is doing it now. Personally, I would not run a 9L in an Emaxx when the xl is a better option. IMO
That would be me, yeah its a good setup. I'm running it with 12 cells , but might be going to 4s lipo's soon. Speed wise it runs great on a track and bumpy surfaces, but on smoother surfaces it might be a little slow. If you want more speed, go for the 8XL, there is another (i think Finnster, has this combo with 14 -16 cells NIMH). The only thing you need to do is to remove the middle wire from the esc plug and use a reciever pack or UBEC, I also changed the mamba plugs to 5.5mm to work with the wanderer i got.
