zeropointbug
Z-Pinch racer
zeropointbug's Avatar
12.01.2006, 12:52 PM
Well, im stuck in a bind! They should have used small HeatPipes to conduct the heat from the top set of FET's to the bottom ones and case. Why would it make such a difference cooling only the bottom ones?? This is weird.
I THink i might just lap the bottom of the case and use A.S. to conduct heat away into the upper Alum chassis brace on my vehicle...
I live in Canada, so even in the summer, i would only drive the car max 25 degrees Celsius, and i don't drive that hard either. So maybe just doing what i will do will be good enough?
Do you guys that have dont the mod, do you get noticeable longer runtime?
