Programming MGM 80 amp with 5300
widemouthmaxx
widemouthmaxx's Avatar
Programming MGM 80 amp with 5300 - 05.27.2005, 05:11 AM
I've been hounding Mike with pm's so I thought I'd ask advice from others on this one...I got the motor and ESC all soldered up nicely. I will be running either 6-7 3300 cells in my MF2 with 19-21 tooth gearing...the set procedure seems pretty easy after reading it a thousand times :rolleyes: anyway I think I got it now..so anyway when it comes to a couple of parameters please give me the best setting for the following:
Timing? (what is timing anyway?)
Range of Neutral Zone?
Automatic Correction of the Neutral ater Switching-on?
....other than that it all looks good...alos what would be the best solution for keeping dust out of the motor..there is a lot of space where the wires come out
Thanks
