01.28.2007, 04:48 PM
Thanks guys!
@sleebus: With Lexan scissors, then using a dremel sanding wheel for the fine stuff. As you can imagine, it took a while. I'm sure if you look closely, you'll see a couple imperfections. Also, one of the holes is about 1/4mm off center, but since the 3mm holes were drilled with a 1/8" bit, there is enough play to make it work. If this doesn't leak when in use, maybe Mike can make up a rubbery-type batch for non-Kyosho diffs?
@***RC***: It's going to be primarily for racing. And it has to look pretty as well as perform. :)
