glassdoctor
TEAM FUSION
glassdoctor's Avatar
03.05.2007, 04:50 PM
Hmmm.. that's a big topic here... the MM and Neu combo.
I'm doing it... but it's tough to recomend it due to the potential cogging problems.
EDIT: I did just take the MM out of the CRT and put in a 125b... which seems buttery smooth.
With the motor wires direct soldered, I'm having pretty good results. But there is still a bit of cogging occasionally. So far it's not bad and I could recomend it if the other advantages outweigh this flaw.
But I'm concerned that a bad episode of cogging could ruin a MM. That happened to me recently. (before removing the 4mm connectors and hardwiring it)
IF Castle comes through with a software update to fix it... then I will absolutely recomend this setup to everyone!
BTW, I have heard from more than one person that the MM works awesome with a Pletty Maximum... zero cogging so they say. So i have faith that CC can fix this issue.
Jammin CRT MM/Neu 1515 1700kv
Losi 8IGHT MM/Neu 1512 1900kv
Kyosho 777
T4 MM 5700
B4 LRP
XX4 MM 7700
