03.12.2007, 12:08 PM
Good point about the Dremel; it can "get away from you". I'm just so used to using a "Kung-Fu grip" than it's not an issue anymore. :) But, it certainly did take some getting used to!
Finnster: By "stock driveshafts", do you mean stock emaxx or stock Revo shafts? The emaxx shafts will probably twist under BL power. The Revo ones, being larger in diameter, may rub on the chassis (as you pointed out) and/or on the ends of the Revo bulkheads. Again, a little dremel (or hand file) makes short work of this...
