rcjmaxx
03.14.2007, 08:12 PM
Originally Posted by BrianG
Not much involved; basically just disable the on-board BEC by removing the red wire in the throttle cable, and then using a BEC for your servo(s)...
The deed is done,car runs great,thank you much.If I did it correctly this setup leaves me with 2 on/off switches,the stock MM turns on the ESC and the receiver switch turns on the steering servo.Is this how its being done or is there a way to eliminate one switch?
